Added Spacers to even lasers
A project log for 3D Laser Array
Make a laser array using servos
bill-weilerBill Weiler 11/07/2022 at 18:090 Comments
I cut some nylon spacers at MakerNexxus. I tried to make each square and 42mm long with the band saw and the circular sander but they didn't come out perfect. I used a heat gun to melt the hot glue to move the servos, but some servos melted and came apart. They all worked when I plugged it in.
