Intent
I'd been building a bunch of tiny devices around the house with a "used future" aesthetic,and going overboard applying a tutorial at Emily's Electronic Oddities (Make 3D Prints Look Like Distressed Painted Metal). The Hackaday contest provided a reason to get started on a Cyberdeck, and more importantly: a deadline. My criteria for the final product were pretty broad:
Parts
Monitor housing, keyboard tray, keyboard housing - from raw to painted
Process
Tinkercad. So much Tinkercad.
Bottom for Pi, power, and keyboard... and a handle that needs post-processing before I can attach it
Monitor housing with insert for vent and monitor switch
Exploded view of monitor housing, with monitor switch assembly and vent insert
Exploded view of keyboard housing, with Pi housing and monitor mount hinge. Also superfluous handle.
Problems and lessons learned
Well, it looks like junk. That's what I was going for, but there's a number of issues that really add to that effect to an extreme I'm not fond of. There's clearly a problem with the part fitting.
There are things that haven't been finished, in order to meet deadline.
And then there's the general hardware issues.
Next steps
Well, fix the above problems, for a start. Next up:
Finally
If you got this far, thanks for reading! Or skimming and stopping here! I'm really glad Hackaday had this contest, as it gave me a reason to pursue this project to some sort of phased conclusion. The entries in this contest are amazing, and I really should be learning from those in whatever comes next for this thing.
