Assembled the Map's Frame
A project log for The Interactive Air Quality Map
A Physical Touch Reactive Map that shows the Air Quality of a location
ahmed-oyenugaAhmed Oyenuga 10/13/2022 at 01:490 Comments
I used a combination of 3d printed parts (White parts), CNC cut acrylic, with a 4mm thick aluminum composite board as the back panel to give the map rigidity.
Aluminium Composite
Aluminium Composite
