The project needs a circuit design for testing, which takes some parameters from the fabricator to design the required line widths and clearances.
In this step, it is necessary to do a quick job mainly to check that the schematic diagram is actually working as expected. Today, the project completed this design board, now only need to put it into the machine to complete the circuit board, next will solder the components.
The project intends to make a 6-layer circuit for the final version, and the test circuit needs to be done quickly, so it will do 1 layer.
Continue to update...
Project manager and chief engineer: Mr. Tran Vinh Quang.
