Bloat Code Tracker
A project log for Source Code Analysis: PowerShellEditorServices
Source Code Breakdown of PowerShellEditorServices (at the time of v3.5.4)
nicholas-jacksonNicholas Jackson 10/31/2022 at 23:040 Comments
This repository is ridiculously bloated
This log will be used to track all known instances of bloatcode in the repo
Unneccessary profilepath processor code
The code that follows this line can be reduced to this:
PSMemberInfoCollection<PSPropertyInfo> profiles = profile.Properties
ProfilePaths = new ProfilePathConfig
  AllUsersAllHosts = (string)profiles.AllUsersAllHosts.Value,
  AllUsersCurrentHost = Path.Combine(
    Path.GetDirectoryName( (string)profiles.AllUsersCurrentHost.Value ),
    $"{HostProfileId}_profile.ps1" ),
  CurrentUserAllHosts = (string)profiles.CurrentUserAllHosts.Value,
  CurrentUserCurrentHost = Path.Combine(
    Path.GetDirectoryName( (string)profiles.CurrentUserCurrentHost.Value ),
 All referenced Enums and Methods for this generation can then be deleted
Unused EditorServicesLoader.Create() signature
According to this search, this signature never gets used.
Literally any instance of Object.Create()
We don't need to reinvent the "new" keyword. Named constructors should only be used where verbose names make the constructor look like more than just a constructor. For example Int32.Parse() is a good named constructor; Int32.Create() is not
ModulePath Modifying functions could probably be merged
EditorServicesLoader.UpdatePSModulePath() should probably include the code from the CreateConfigObject method on the cmdlet
Usages of PowerShell translated to C#, instead of just using C#
instead of using System.Text.Json to serialize to Json, they use the PowerShell command ConvertTo-Json to do it instead, but from C#. This is one of the most hilarious instances of bloat code I have ever seen
ProfilePaths is literally reinvinted just to be used as a parameter. No additions, just cloned into a new object.
This code doesn't need to be here.
Modifications to the BundledModulesPath variable
this doesn't need to be done in 5 different spots across the utility. Jesus Christ
