Using the most popular and basic example to create a Hello World Example with Tensorflow Lite for microcontrollers. An LED will blink based on a Sine Wave.
Open the example, “Files” -> “Examples” -> “TensorFlowLite_Ameba” -> “hello_world”.
3
Upload code and run
Upload the code and press the reset button on the Ameba board once the upload have completed. Connect the LED to digital pin 10 and ground, ensuring that the polarity is correct. You should see the LED fade in and out rapidly.
