C-SDK, arduino-pico or MicroPython
A project log for Ethernet microphone with PoE (active or passive)
Single MEMS microphone with audio over UDP, using only RP2040 and INMP441 and just 3 resistors! (and an RJ45, plus some more for active PoE)
biemsterbiemster 10/25/2022 at 15:020 Comments
There are no less then three very well supported ways to program a Raspberry Pi Pico, all with a great and active community:
  1. The official bare C-SDK
  2. arduino-pico, based on the C-SDK, but using the familiar .ino sketches.
  3. MicroPython / CircuitPython
So first thing is to decide which one to use in this project. The two main requirements are SPI input for the INMP441, and the ability to use https://github.com/kingyoPiyo/Pico-10BASE-T for sending the audio frames over Ethernet.
Funny thing is, the 10BASE-T code by kingyoPiyo is written for the C-SDK, and only arduino-pico and MicroPython have SPI input! (the SPI code in the C-SDK is output only as of yet)
So for now I have chosen to go with arduino-pico, since it should be relatively straightforward to use the 10BASE-T code as a library in Arduino. I've never done this before, so keep your fingers crossed.
