INMP441 readout on RP2040
A project log for Ethernet microphone with PoE (active or passive)
Single MEMS microphone with audio over UDP, using only RP2040 and INMP441 and just 3 resistors! (and an RJ45, plus some more for active PoE)
biemsterbiemster 10/25/2022 at 15:224 Comments
So I have chosen the arduino-pico environment for this project. SPI is quite straightforward to work with, but keep in mind that the LRCLK (=WS) has to go on pin BCLK +1 due to limitations on the PIO in arduino-pico.
The SPI is setup like this:
#include <I2S.h>
I2S i2s(INPUT);
int32_t l, r, sample;
void setup() {
  pinMode(1, OUTPUT); // L/R
  digitalWrite(1, LOW); // LOW=LEFT, HIGH=RIGHT
  i2s.setDATA(29);
  i2s.setBCLK(3); // LRCLK = +1
  i2s.setBitsPerSample(24);
  i2s.begin(16000);
and after this can be read out:
void loop() {
  i2s.read32(&l, &r);
  sample = l ? l : r;
  Serial.printf("%.6x\n", sample);
This will output 3byte 24bit samples on the UART, which can be played back on a Linux machine using the following commands:
$ cat /dev/ttyACM0 | xxd -r -p | aplay -r16000 -c1 -fS24_3BE
The call to xxd turns the hexadecimal samples into raw bytes.
This code and the pin diagram is available in https://github.com/biemster/arduino-pico-serialmic
louis.croisez wrote 04/13/2023 at 17:49 point
I am newbye concerning the Rpi-Pico 2040 board, so I have no advice concerning your switch to C-SDK. I suppose that you have very good reasons.
On the other hand, speaking about the sample rate, I think that the limiting point is the sensitivity of the INMP441 mic, which does not allow to get up to 20kHz bandwidth. I found another microphone which seems to be able to give samples in such freq range:
ICS-43434
biemster wrote 05/03/2023 at 21:54 point
The switch to C-SDK was because the ethernet lib uses it. I'll probably agree with you that the INMP441 is a bit underspeced when I look into it, but that's the one I had on hand and came cheap..
louis.croisez wrote 04/13/2023 at 09:32 point
Thank you for this project.
The sample rate is configured to 16KHz. Could the pico accept a 48KHz sample rate ?
biemster wrote 04/13/2023 at 16:11 point
I don't see why not, and I kind of remember trying this as well (but not sure).
Keep in mind though that I have seem to swapped to C-SDK code instead of arduino-pico, as I noticed in https://github.com/biemster/pico-ethermic.
This project got stalled a bit since I did not get the PIO ethernet to work yet.
