Simple Scintillation Counter Example
A project log for Mini SiPM Driver Board
Drive silicon photomultipliers (SiPMs) and build yourself a simple scintillation counter quick and easy!
nuclearphoenixNuclearPhoenix 11/18/2022 at 18:480 Comments
Hi, today I built a simple scintillation counter using an 128 x 32 px OLED and a Raspberry Pi Pico with the Mini SiD board. It's very temporary just as a showcase, but you could obviously build everything much tighter without all these jumper cables. Also the scintillator was too large to put onto the PCB as you can see.
It's just a simple "device", but what more do you need for the beginning, right? The display updates every 2 seconds and displays the average number of cps that accumulated over this timespan.
Everything was, once again, programmed using the Arduino IDE. You can have a look at the sketch here on GitHub: https://github.com/Open-Gamma-Project/Mini-SiD
Cheers!
