Electric Longboard-Leather Edition
Tinkering project to build my own electric skateboard
Electric skateboard built with custom 3D printed/Machined parts/leather parts, VESC, WiMote, Vanguard Deck.
Attempt 1 was with customer Arduino code/wiimote and a RC boat ESC. Forward was ok breaking.....Broken ESC. Moved to VESC
Attempt 2 loose wires around powered VESC.... shorted MCU
Attempt 3 1 Hot-air rework station, new MCU and some troubleshooting and it was good to go.
Currently the main issue is VESC is cutting out at full throttle. Have messed with current limits, voltage low limits, increased power caps still no solution. Next step is a VESC swap to see if that fixes the issue. TBD
  • Controller Update
    dgragnolati02/08/2017 at 18:16 0 comments
    Started on a new controller to replace the NunChuck. Goals of controller below.
    1 . Rechargeable with level indicator
    2. Pull data from the VESC and feed to controller (Battery Life of Board)
    3. Slim up the form factor to fit in pocket better
    Currently going at it with HC-05 Modules and Arduino platform
View project log
