The Nixies are Alive
A project log for Radiant Dice
Geiger counter based random number generator/dice roller
andrew-woodbridgeAndrew Woodbridge 12/31/2022 at 16:150 Comments
Received and partially populated the circuit board. I wanted to test as I went since this is my first circuit board., and my first high voltage project. As I added components and test, everything seemed to be working without issue.
On the code side, I updated the code to incorporate the Nixie Tester drivers, and the external OLED.
