Front Panel Finishing
A project log for Radiant Dice
Geiger counter based random number generator/dice roller
andrew-woodbridgeAndrew Woodbridge 01/06/2023 at 03:510 Comments
I completed the front panel today.
  1. Laser cut 3mm white acrylic for the front and back layers of the panel
  2. Attached the panels together (IPS Weld-On 3 Acrylic Plastic Cement)
  3. Spray Painted them with a Matt Dark Green from  Rust-o-lium
  4. Taped down and cut a piece of cardstock for alignment, and burned away the paint leaving the white behind
  5. I then mounted everything.
Up next:
