I have tested the supply voltage for a 6S battery (25.2V max)
You should be able to use any 2-6S LiPo/LiIon battery to power it
White = Ground/Negative Input
Red = Positive Input
Drilled some holes into the housing to route cables to the outside for a XT60 connector.
Also had to remove one screw socket to make room for those cables.
