FLEXTRUDER2 M: Dual drive remote direct extruder
Simple and effective dual drive extruder with a remote motor and flexible shaft transmission
Public Chat
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This is a preview of the medium FLEXTRUDER2 extruder with 25 tooth geared wheels.
This design has a side-opening lever: It has 2 advantages:
* The gears stays nearer to their designed gear-center distance, whatever the filament diameter.
* The gears are lower, less distance between the gears, heat sink and hot end.
See the FLEXTRUDER2 S project for more information about this concept.
