A little extra for the detail section.
A project log for 18650 Holders
18650 battery holders that do not require soldering or spot welding.
cyplesmacyplesma 11/30/2022 at 00:580 Comments
Adding to the description, The 3D printed holders use a twist lock. I do still need to add a retaining block so you have to push and twist the pieces to separate or join them. I have uploaded the STL files and the FreeCAD files to my github. The twist does use the standard lefty loosy and righty tighty action.
