Setback Solution
A project log for 18650 Holders
18650 battery holders that do not require soldering or spot welding.
cyplesmacyplesma 12/11/2022 at 17:370 Comments
Seems it was just a couple of batteries that had the issue of not providing contact with each other. Not an issue with the holders themselves. But I will have to setup the holders with a through hole for the battery sensing wire for the BMS. That will make sure this will work for any battery. As it is now I will definitely have to test the batteries I want to use in these holders.
