• 1
    Add Raspberry Pi
    Attach the ribbon cable from the raspberry pi to the screen and put the two wires in connecting the power. Screw the raspberry pi into place.
  • 2
    OS Download
    Go to Emteria.com and download the installer. Once that is done, open the installer and follow the steps to download the OS onto the SD card. Plug it into the raspberry pi and turn it on. Follow the setup instructions. If you tap a few times on the thing you are writing on a keyboard should come up.
  • 3
    Printing
    Print the case and attach it.
