The project status
A project log for XiAleste
XiAleste Next is an 8-bit home computer, which is compatible with software for the Amstrad CPC6128 released on 13 June 1985
h2wh2w 12/07/2022 at 08:520 Comments
Project Status Summary as of December 7, 2022.
The schematic diagram is 95% complete. There are some details left, but overall this is the final. Apparently I managed to make the bus workable from the PDC connector from Amstrad -- with minimal modifications. As in the A520 the connector had to be enlarged to 62 pins. The design of the overall synthesizer structure was also completed.
The DTX format PCB has the placement of all components, and there are already some traces. The printed circuit board contains the following interfaces:
The following tasks remain to be done:
