• 1
    Step 1
    The button is used to reset the settings. Pressing this button when the device is turned on allows you to reset the settings to default mode.
    The default mode is set automatically after the firmware if there was no data in the EEPROM memory.
    Default mode means launching the APK of the access point with the address 192.168.4.1 SSID:TERM-SNMP
    SNMP Community RO: Public
    The SNMP OID consists of a prefix .1.3.6.1.4.1.2020.1. , which can be changed in the settings, next .1 - degrees Celsius .2 - degrees fahrenheit, which is the temperature sensor number
    example: .1.3.6.1.4.1.2020.1.1.2 - displays the temperature in degrees Celsius of the second sensor
    The numbering of the sensors is displayed on the first page of the setup
    Supports up to 10 sensors
