Waiting on a Part
A project log for Hardware Controlled 4 bit CPU
A hardware controlled 4 bit CPU based on lessons learnt from the TD4 and the CHUMP CPUs
agpcooperagp.cooper 01/28/2023 at 01:100 Comments
PCB Assembly
I have started assembly of the PCBs but I am waiting on a part.
Instruction Set
I have had time to think about improving the instruction set.
The idea came from the number of steps required to swap out the accumulator to memory. Better if I have a register and a swap opcode.
The idea actually frees up the opcode space as I can use the opcode "data" to specify the  register and the registers can serve other purposes (e.g. the page register).
I need to look at how the memory data flow works as well.
Rebuilding the Micro-Architecture
I took the well published academic RISC micro-architecture:
And derived the CHUMP micro-architecture:
But along the way I saw an alternative memory arrangement:
This configuration has three benefits:
I have tested the new micro-architecture in Logic-Sim (and it works fine.
Adding Registers to the CPU
This allows the inclusion of register read/write logic:
In the above drawing I will probably keep the old PC and JNC logic.
Now I can replace the Page opcode with a register(s) read/write opcode.
Working LogiSim Version 7
Have been working on the Version 7, it now has register read/write opcodes. Added four registers of the eight available slots:
Swapped the Page opcodes (Ex/Fx) with JNC opcodes (8x/9x).
Replaced the new 8x/9x opcodes with 8r/9r were r is a register constant or memory reference:
Here is the Top Level:
The Control Unit:
The ALU:
And the PC:
Overall a pretty significant improvements on CHUMP V5 and the 4 Bit CPU V6.
Here is the test code (the multiply algorithm):
This algorithm uses the new JNC and REGs opcodes, and multiplies F x E (13 x 14), the result is D2 (210).
Parts have Arrived
The parts have arrived. Finished off one of the Diode ROM boards, next is the CPU board:
TBC ...
AlanX
