USB module not regulated
I hate the batteries.
When I can, I modify system, to replace batteries's system with powersupply.
This project is sponsored by PCBWAY
Public Chat
This module was designed to supply Christmas lights
or other, which no need regulated current and many power.
This new version (REV2) can detect surcharge current, over 1,9A. This system commands a simple LED, with a transistor, but you can use this, to command a relay or other.
This system isn't regulated.
To use that it must follow next steps :
1. Plug the system to the USB NOT to the charge yet, and set voltage to 0V
2. Estimate voltage to your charge with the number of battery. For example 2 batterys = 2 x 1,5V = 3V
3. Plug the charge to the terminal block.
4. Set the voltage with the potentiometer.
usb_alimREV2.1.zip
This zip contain : - Gerber zip if you want product PCB with PCBWAY - Source files designed with KICAD - Git directory to follow version.
Zip Archive - 2.23 MB - 05/14/2023 at 10:09
Download
View all 12 components
  • REV2.1
    Anthony Fernandez05/14/2023 at 10:22 0 comments
    Hello,
    I updated this USB module by adding an additional current sensor DIY.
    I updated the project files, and the list of components.
    Enjoy IT !
View project log
  • 1
    Download and extract file
    Extract the zip file.
  • 2
    ZIP gerber
    Go to the PCBWay website, and click on "PCB Prototype" button.
  • 3
    Upload Gerber files
    Give the size of the board :
    82x34 mm, choose minimum quantity and click on the calculate button
View all 5 instructions
