Decoration Deployment and Recovery Tool
This project is a 3D printed tool that attaches to the end of a pole to attach and remove decorations from trees.
This project created a 3D printed tool that attaches to the end a pole. The tool has a deployment head and a removal head. This tool was created so that decorations could be placed in trees without the use of a ladder. Watch the video .
The ground around trees is often soft which allows the legs of the ladder to sink into the ground unevenly. The ground is often not flat. Some trees are cone shaped making it hard to reach the higher levels of the tree. Each year, there are more than 164,000 emergency room-treated injuries and 300 deaths in the U.S. that are caused by falls from ladders. The tool has an optional camera arm that allows a close up view when a long pole is employed. The Hmude 2023 Upgraded Mini Camera HD 1080P Home Security Camera Detector - Indoor Camera Home Security Camera Wireless WiFi Camera from amazon was used. The parts are fastened together with 2 mm and #6 drywall screws. The camera has a magnetic back that attaches to a large washer glued to the printed part .
DeployNrecover.mp4
Video showing the tool in use
MPEG-4 Video - 38.59 MB - 01/23/2023 at 20:46
Download
ReadMe.odt
Printing Information
text - 9.13 kB - 01/23/2023 at 20:43
Download
BandClip.stl
Bottom elastic ban retainer
Standard Tesselated Geometry - 450.96 kB - 01/23/2023 at 20:30
Download
Jaw.stl
Movable jaw for recovery
Standard Tesselated Geometry - 977.52 kB - 01/23/2023 at 20:30
Download
CameraRiser.stl
Attaches to camera arm
Standard Tesselated Geometry - 222.15 kB - 01/23/2023 at 20:30
Download
View all 10 files
Alan Campbell wrote 01/26/2023 at 22:55 point
Sorry, I live in a no fly zone near an airport :(  Maybe someone else can run with the idea.
Dan Maloney wrote 01/26/2023 at 22:40 point
Very clever! Now, if you can attach it to a drone...
