This thing comes with also open-source BLDC driver which you can find in the link below :
https://hackaday.io/project/188219-a-simple-bldc-driver-module-for-beginners
The gears are adopted from Open torque but I changed them slightly.
This is a high-torque yet affordable servo motor
including a low KV BLDC motor, 3d printed planetary gearbox, and BLDC driver
Standard Tesselated Geometry - 1.88 MB - 03/14/2023 at 05:59 |
Standard Tesselated Geometry - 1.49 MB - 03/14/2023 at 05:59 |
Standard Tesselated Geometry - 730.06 kB - 03/14/2023 at 05:59 |
Standard Tesselated Geometry - 1.65 MB - 03/14/2023 at 05:59 |
Standard Tesselated Geometry - 1.68 MB - 03/14/2023 at 05:59 |
For printing gears, I recommend using ABS or PC if it's possible. With 2mm skin and between 30 to 50 percent infill.
For other parts, I personally used PLA with 25% infill and 2mm skin. PLA's elastic feature really helps the robustness of the structure.
This part actually made out of a laser-cut aluminum sheet with 2mm thickness.
You also can 3D-print it if you want, But!!!!!! it might be good enough for small torques. Although, if you go higher than 3Nm you can see the plate start to stretch so you might want to increase the thickness.
Hello Jensen, The gear ratio is 8:1.
The motor is not coreless, so It gonna show cogging a little when It's off. But
despite that, It is back driveable.
Hi, your project is very nice. I'm considering trying it out. I was wondering, You provides 2 files, one in .f3d and the other in .iges format. can you please provide both in fusion 360 format so I can have the design history?
Hello Amanda, I've uploaded it. please check the files.
This one looks pretty good, might even be worth a write-up for the blog. Looking forward to seeing more build information. Keep us posted!
Hi Dan. I'm glad that you liked it. I'll keep posting details. stay tune :)
Hi Navid, is the actuator back drivable, or is the gear ratio too high?
