Test 3
A project log for Backflow starship incense burner
A starship model with real smoke exhaust
lion-mclionheadlion mclionhead 01/28/2023 at 22:080 Comments
This one did the best of all of them.  Depending on wind direction, but much less so, it managed the best spreading of smoke.  There is always going to be a need to carefully level it & block wind.  Longer cylinders might improve it.  The mane problem is the metal gets super hot.  It might have to be ceramic.
A longer, narrower exhaust pipe made it diffuse evenly in more wind, but it was still sensitive to leveling.
The 20mm diameter melted as expected, despite being made of PETG.  Creating a ceramic hot plate is the great task.
A bigger diameter than 36mm could make it heat resistant.
