• Day 5 : Ext. UART & some GFXs
    Franck GALLIAT03/11/2023 at 17:56 0 comments
    Hi, for today we have ...
    I started to use my Aux UART (for DOWNLoad / UPLoad binary files w/ a computer), keeping UsbUART to debug/program calculator native code.
    Then I re-used my good old .BP4 file format (for 16greyshades pictures) to display pictures on SSD1322 (256x64x4bpp display)
  • Internal Diagram
    Franck GALLIAT02/09/2023 at 17:23 0 comments
    The inner diagram with both MCUs (AT328P / RP2040) & both power system
  • Day4 : Battery Party
    Franck GALLIAT02/09/2023 at 16:21 0 comments
    Hi, today I finally mounted a battery pack, it's a rechargable NI-MH 4xAA 1.2v.
    It provide a 4.8v @2400mAh, enough to power the 2x screens, 2x MCUs, keyboard ...
    so now, system can be both power by USB connector / 4.8v battery
  • Day3 : enclosure is ready
    Franck GALLIAT01/28/2023 at 19:37 0 comments
    January 2023, 25th :
    The build is ready to be enclosed. there is less room that I imagined.
    I had to forget a lot of ideas such as mounting MCU on removable cards to change the CALC behavior (WiFi, dumb terminal, calculator....)
  • Day2 : unsoldering & experiments
    Franck GALLIAT01/28/2023 at 19:34 0 comments
    During January 2023 :
    unsoldering much as possible original parts
    & start to experiment existing wirings..
  • Day1 : unboxing
    Franck GALLIAT01/28/2023 at 19:31 0 comments
    December 2022, 31th
    received the non-working Unit in pretty good looking state.
    I still work on software part w/o be sure of screen size, keyboard map... that I will be able to re-use.
