This was the first time I had ordered gold-plated boards (ENIG process), and damn were they more expensive, a scratch over triple what I usually pay per board. I think the cost was worth it though when I saw and held them.
Assembly
Assembling the boards was pretty basic, I just hand-soldered everything in place. In order to bring the DIP8 package for the ATtiny85’s close to the board I cut the leads a bit shorter with side cutters.
A minor side note, but I really like the look of parts on these gold-plated boards before soldering.
Plating the Belly and Eyes
Since we wanted the belly and eyes to be silver I had to hand coat them with solder. This was easier than expected although the belly cooled quickly so the soldering iron would leave “ripples” of solder as it moved across the surface, like a paint brush.
I found that if I applied hot air as I moved the iron I could prevent the rapid cooling and result in a smoother belly plating. The effect is quite similar to Hot Air Solder Levelling (HASL) typically done for cheaper boards.
I was a bit torn between the entirely hand soldered or air levelled belly coat. In the end, I hand soldered bellies for the ones I handed out since it was easier and I felt there really wasn't that perceptible a difference.
