• 1
    Soldering the main components
    Layout your sockets on the pcb and solder.
  • 2
    Connecting the wires
    ZX          EEPROM
    Memrq -> oe
    A0-A13 -> A0-A13
    D0-D7 -> D0-D7
    5v/gnd -> 5v/gnd
    Pull the eeprom we and a14 high.
    Connect the the zx a14 and a15 to pin 1 and 2 of the 74ls32 then pin 3 to ce pin of the eeprom. Also Connect the 74ls32 to 5v and gnd.
    Pull zx memrq high.
    This will allow you to play burnt eeproms on the zx spectrum.
  • 3
    Toggling the interface
    Using a double throw switch connect similar to below
    X  -------- 5v
    Memrq---74ls32 pin 5
    5v---------gnd
    Connect pin 3 to pin 4 of 74ls32.
    Finally connect pin 6 of the 74ls32 to the ce pin of the eeprom.
    Now you can toggle between zx spectrum and the new eeprom interface!
