Latest and greatest
A project log for Openthing 1 - ESP-CM3
ESP32-S2 based Module as drop-in replacement for Raspberry Pi's Compute Modules CM3
mirkoMirko 12/15/2023 at 13:360 Comments
I received the new prototypes of the ESP-CM3 and the programmer and everything works perfectly fine!
If you can see it... look very close... what does the ESP say?
exactly.. it is an ESP32-S3 Version!! woop woop - turned out that ESP32-S2 and S3 are somewhat footprint compatible!
