Let's design a cover first
A project log for Hydro flask adapter for Soda stream
3D printed adapter to use hydro flask bottle directly with soda stream
karl-st-arnaudkarl St-Arnaud 02/11/2023 at 22:030 Comments
To overcome the leak issue, I decided to use a replacement rubber gasket of hydro flask in my design. To test how much water tight my design was, I decided to start my designing a cover instead of going directly for the adapter.
hydro flask cover
Improve thread
I received a caliper as a gift that help me take more precise measurement of the hydro flask thread. This created a much more water tight interface.
Leak through the plastic
The first iteration I did had leak through the plastic itself. Here are some modification I brought to my design and printing process to get a water tight print
Result
In the end, the final cover was tested with for 1h with the bottle tilted and couldn't find any leak of water.
I provided in the files section, the stl file of the hydro flask cover.
