Solenoid and pump test
A project log for BottleBot - Bottle Filling Machine
Conveyor belt and a filling station using arduino- bottling my home brew beer!
functionaldesignFunctionalDesign 12/18/2016 at 19:050 Comments
On the road to a fully automated bottle line there will be lots of testing and errors. I have now tested the pump and solenoid and measured the time needed to fill bottles with the current setup. I have ordered flow meters that I will incorporate into the design, but right now I need to understand how the pump and solenoids affect the flow, and how I can control it.
I have designed a rough holder for the solenoids and the pump that can hang on a plastic container with water. A tube goes from the water to the pump, and from the pump to a (leaking) Y-connector that splits into two tubes for each solenoid valve. I have set up a circuit nearby (on the BottleBot conveyor belt) and use arduino nano to control everything.
This basic setup works OK. Below are the results after test filling a beer bottle (0,33L). The tube from the pump is approx. 6 mm ID and the tubes for the solenoids are approx. 4 mm. So for curiosity I also checked the time for filling a bottle from the pump itself.
Filling 1 bottle (one solenoids open, one closed)Filling 2 bottles (both solenoids open)Filling a bottle directly from the pump tube
test 133,20 seconds44,4 seconds13,25 seconds
test 233,12 seconds43,23 seconds12,74 seconds
test 333,41 seconds44,18 seconds12,87 seconds
Filling two bottles at the same time is about 22 seconds for each bottle. It basically mean I have 22 seconds to grab the bottle, put a cap on it manually and put it into the crate. Considering this is a tabletop bottle line assisting me with my home brew I think it's acceptable.
Filling the bottles with two pumps with 6 mm tubes would be effective. The drawback is that the size of flow into the bottle makes the liquid splash a lot, which can be bad for some beer types. The flow from the 4 mm tubes, or out of the solenoids itself, are straight and clean and makes no splashing or bubbles in the bottle.
Circuit designed in Fritzing. Pressing button 1 turns on the pump, pressing button 2 turns on solenoid 1, pressing button 3 turns on solenoid 2.
Sources and inspiration for using TIP120 transistors and controlling motors and solenoids:
I have struggled with bugs in either the code or the circuit itself and added LED's for each function to get a visual feedback when things should be on or off.
Problem is that a solenoid may suddenly turn on by itself (also turning the green LED on). This can also happen when I press another button. For example, turning off one solenoid may turn on the other one at the same time, even though only one button was pressed.
/* Anders Holm 18.dec 2016 - FunctionalDesign https://fdproj.wordpress.com/
Controlling 2pcs 12V Solenoids and 1pcs 12V Pump with Arduino
This demonstrates how to control solenoids and a pump using pushbuttons with debounce
and TIP120 Transistor with Arduino.
 The circuit:
 button1 for pump - Digital Pin 2
 button2 for solenoid- Digital Pin 3
 button3 for solenoidmp- Digital Pin 4
 TIP120 Transistor for solenoid 1 - Digital Pin 07
 TIP120 Transistor for solenoid 2 - Digital Pin 08
 TIP120 Transistor for 12V pump - Digital Pin 11
 Based on http://www.arduino.cc/en/Tutorial/Debounce
// constants won't change. They're used here to set pin numbers:
const int button1Pin = 2;     // the number of the pushbutton1 pin - pump
const int button2Pin = 3;     // the number of the pushbutton2 pin - solenoid 1
const int button3Pin = 4;     // the number of the pushbutton3 pin - solenoid 1
const int Solenoid1pin =  7;  // the number of the solenoid1 pin
const int Solenoid2pin =  8;  // the number of the solenoid2 pin
const int pumpPin =  11;      // the number of the pump pin
// variables will change:
int button1State = 0;         // variable for reading the button status
int button2State = 0;         // variable for reading the button status
int button3State = 0;         // variable for reading the button status
int lastButton1State = LOW;   // the previous reading from the input pin
int lastButton2State = LOW;   // the previous reading from the input pin
int lastButton3State = LOW;   // the previous reading from the input pin
long button1_lastDebounceTime = 0;  // the last time the output pin was toggled
long button2_lastDebounceTime = 0;  // the last time the output pin was toggled
long button3_lastDebounceTime = 0;  // the last time the output pin was toggled
long debounceDelay = 50;    // the debounce time; increase if the output flickers
int PumpState = LOW;
int Solenoid1State = LOW;
int Solenoid2State = LOW;
void setup() {
      // initialize the pushbutton pin as an input:
      pinMode(button1Pin, INPUT);
      pinMode(button2Pin, INPUT);
      pinMode(button3Pin, INPUT);
      // initialize the relay pin as an output:
      pinMode(Solenoid1pin, OUTPUT);
      pinMode(Solenoid2pin, OUTPUT);
      pinMode(pumpPin, OUTPUT);
      // set initial state for pump and solenoids
      digitalWrite(Solenoid1pin, Solenoid1State);
      digitalWrite(Solenoid2pin, Solenoid2State);
      digitalWrite(pumpPin, PumpState);
}  //end setup
void loop(){
check_button1();
check_button2();
check_button3();
} //end loop
void check_button1()
   int readingButton1 = digitalRead(button1Pin);
    if (readingButton1 != lastButton1State) {
    button1_lastDebounceTime = millis();    // reset the debouncing timer
    if ((millis() - button1_lastDebounceTime) > debounceDelay) {
    if (readingButton1 != button1State) {
      button1State = readingButton1;
      if (button1State == HIGH) {
        PumpState = !PumpState;
    lastButton1State = readingButton1;
} //end check_button1
void check_button2()
   int readingButton2 = digitalRead(button2Pin);
    if (readingButton2 != lastButton2State) {
    button2_lastDebounceTime = millis();    // reset the debouncing timer
    if ((millis() - button2_lastDebounceTime) > debounceDelay) {
    if (readingButton2 != button2State) {
      button2State = readingButton2;
      if (button2State == HIGH) {
        Solenoid1State = !Solenoid1State;
    lastButton2State = readingButton2;
} //end check_button2
void check_button3()
   int readingButton3 = digitalRead(button3Pin);
    if (readingButton3 != lastButton3State) {
    button3_lastDebounceTime = millis();    // reset the debouncing timer
    if ((millis() - button3_lastDebounceTime) > debounceDelay) {
    if (readingButton3 != button3State) {
      button3State = readingButton3;
      if (button3State == HIGH) {
        Solenoid2State = !Solenoid2State;
    lastButton3State = readingButton3;
} //end check_button3
Any ideas on how to get full control of the solenoids when using buttons are welcome.
