[P] Trying the Vivosun 2.4 x 1.2 x 2m Grow Tent
A project log for TrueTent TempLab [gd0143]
Improving my work/life balance by building the office every time I want to "go into the office", ideally with artificial daylight.
kelvinakelvinA 03/01/2023 at 21:060 Comments
I got this in the mail on Monday 27th Feb and was fully aware that, whatever happened, I was sending this tent back. I thought I'd try it anyway since I don't want to return a second tent from things I could've learned from this tent.
For starters, I was expecting to use the box as the storage medium (like a Christmas tree and the box it comes in), but I forgot that cardboard is usually standardised in terms of its strength, and it doesn't like carrying heavy things:
Nothing inside was missing or bent though so I moved on to taking loads of images of everything I could so that I knew how to refold the tent back. This also means that I'm going with the £119 Seuna tent instead of the £109 tent (among other reasons I'll mentiin the next log).
My hypothesis was that putting the metalwork together would be easy and manipulating the fabric would be the bottlneck for both assembling and dissassembling the tent.
Assembly
 Not sure what that cutout of silver fabric is for, but I'm already not a fan of the branding. I did notice (over the couse of working with this tent) that my internal voice was repeating "Vivosun" loads because I was automatically reading text.
Anyway I took everything out and took pictures of every step of the way, because I feel that the majority of growtent buyers are only concerned with putting the tent up and less so of taking it down again.
I took one look at these instructions and new I had to improvise and that it was probably going to take longer than 10-15 minutes, as claimed by product listings and youtubers alike. The thing is, unlike those guys that have an entire garage of free empty space to put this together, I have 2.45 x 1.83m of floor space to assemble a 2.4 x 1.2m tent.
There was also a second rectangle of reflective fabric. under the main tent (and liquid tray). The back of it is a greyish blue.
Little silica bag in there.
2 bits of fabric off-cut are used to tie the ends of the tent fabric.
Unfolding the tent
Just in the event that somone wanted to know how to fold such a tent back up again. There have been many instances where I got something all nicely folded and had no idea how to get back to that state after I took it out of the packaging.
After this is the main fold that turns this 1.2x2m looking thing into a 2.4x2m looking thing.
Looking Around
Some mysterious green fabric square.
The zipper handles are quite large and made of metal:
Moving on...
I thought this velcro-attached flap was nice to hide this middle zipper.
From the sounds of youtubers, I was thinking that 600D was some substantially thick material, but it's 0.4mm thick.
Some mystery thread I'm assuming isn't supposed to be here, so I cut it since it was preventing me from opening the tent fabric.
Putting the frame together
There's essentially 3 types of tube. Long tube with push buttons on each side, short tube with push butons on each side and short tube with a hole on one side and a push button on the other. The short tubes are verticals and the long tubes are horizontals.
I like how there are multiple holes on some so that any valid solution of putting this frame together is possibe.
The green tube is a brighter shade of green than the fabric highlight. I should also mention that the more I looked at this green, the more I thought "Wow. This is really green!". Just... green green. Not LED green, not grass green, not milky green (though that would look great) but some stock standard, Fisher Price, kid-grade green.
For some reason, the middle connectors were the only ones that were stubborn and took some effort to insert.
Those little green dots is some of the paint chipping away trying to coerce the tube inside. None of the other connector types had this problem.
My first idea was to start from the top and build downwards. Obviously that failed, so I quickly deconstructed my attempt and moved the quite heavy fabric so that I could start puting the base tubes in.
Things were all going great until this back left corner attacked. I think there's been a sewing error because none of the other corners have such a fold  and the back line, with reference to the green poles, is visibly not straight. Unfortunately, the threads holding the corner broke midway though trying (and failing to squeeze)  this corner on.
The scene is dark now because the top cover is blocking the overhead ceiling light.
This is what it looks like when all the other 3 corners are in perfectly.  As you can see, I'm miles off where this thing needs to be. If i put this corner in, the front left corner is miles out from where it needs to be.
So, probably after an hour, I moved on and assembled what I could. It did not help that the back top right corner also had a strange fold, just to a lesser extent. It just multiplied the issue in the back bottom left.
Anyway, I was able to assemble... half a tent. But don't worry because I can still get an idea of how this solution would work.
I checked the time and it had just been a minute over 3 hours to get to this point. It's now midnight. The hope was to see if I could dissasemble at this time (since this is when I'd likely stop working in the tent anyway), but since I just did 3 hours of manual work straight, I didn't think I'd get valid results (and I didn't want to break anything, including myself) so I slept and took it down in the morning.
Sadly, that took another 40 minutes.
Conclusions to draw from this experience
Right now the solution is about to fail.
The actual tent experience is great because the walls are reflective and the space feels spacious because the rear wall is a good distance away and I still have enough room behind me to stretch my arms.
The issue is the transit time. I'm looking at the act of moving furniture and building the tent the same way as getting a bike out and cycling to work, which is decent if it's like 15 - 20 minutes, especially since it's integrating a bit of a "gym of life" workout to get my body moving and energised.
While moving all the furniture out of the way, building the tent, installing the ventialtion, running the power cables (and ethernet, now that I think about it since WiFi probably isn't making its way though a metal-lined tent), placing a table+chair in there and then doing all that in reverse feeeels like the merge between a Lego build timelapse and the title screen for Build A Lot 2, the time to do all that needs to come way down or the solution fails.
This is what I'm mostly concerned about with all my projects. In one way or another, the issue usually comes back don to time why the solution fails. That's the reason why many of my active projects are trying to make things less time-expensive and my 3D printer brand is called "SecondSavr".
Hopefully, this is just an optimisation problem because 2.4x1.2x2m is both quite nice inside and conviniently the absolute maximum size my room can accomodate, particularly in height (due to the lighting fixture). The ventilation ports and ceiling mounting arrangements are also things not found in other tents.
However, as I hypothesised, manipulting the fabric slows down this entire operation.
16 March
Long story short...
