Design walkthrough
A project log for Paper WiFi
WiFi/BLE-enabled low power e-paper display devboard
albertas-micknasAlbertas Mickėnas 03/03/2023 at 14:520 Comments
ESP32C3 supporting components is basically just following ESP32­C3 Family Hardware Design Guidelines. There's a footprint for 32kHz crystal, but since it's not supported in Arduino environment, also pins are broken out as GPIO.
Display power conditioning circuit is also provided in a datasheet from GooDisplay
Power section is designed to take in both USB and battery power. U5 is a boost converter and Q3 is responsible for disconnecting batteries when powered form USB and provide reverse polarity protection.
Power to I2C sensors is switched via transistor to save some Coulombs
