Projector Aligned
A project log for DLP Printer Build
Nothing special, just a log of my progress on a DLP printer build. Should be usefull to others in the UK looking for sources etc.
joshua-elsdonJoshua Elsdon 01/24/2017 at 15:500 Comments
Just a quick picture of the printer with projector mounted. Just a few connections to be made to the RPi for the end stops etc. Interestingly, (by design) the projector does not need to be modified for this build area, so this slightly larger design could be seen as 'easier' than the 'LittleRP' design where the focal distance needs to be reduced to allow it to focus on the small build plate.
