2. Homemade Clay with Cornstarch
A project log for 3D Pottery Machine for Kids v2
Cornstarch pottery machine for kids' STEM education
guillermo-perez-guillenGuillermo Perez Guillen 04/08/2023 at 21:030 Comments
Modeling clay has one main drawback: the high cost price. It is a material that, although it is within the reach of most people, it is also true that it is considered expensive for those who do not have a clear idea of its use or simply do not know how to use it correctly yet and, therefore, might think that They waste the investment. For this reason, you can start learning with another material similar to the clay that artists use and it is also convenient to know several methods to make homemade moldable clay in order to have it without having to buy it, because although it is not exactly the same as the used by artists can be used to practice or to entertain children for a long time and get them to learn while having fun.
Many people, when thinking of making homemade clay for children, may also be thinking of a material such as plasticine or polymer clay (also called Fimo). However, although they are moldable materials that may have similarities, several aspects must be taken into account. In the case of polymer clay and plasticine, we can indicate some important aspects:
After knowing all this, we help you discover how to make homemade clay with different easy-to-find materials. We start by teaching you how to make clay with cornstarch, cornstarch or starch or corn flour.
Ingredients
Steps to make homemade clay with cornstarch
  1. Mix the cornstarch with the salt in a bowl. Use the amount you consider appropriate depending on the project you have in mind to work with the clay, but you should always add twice as much flour as salt.
  2. Gradually add water to the mixture. Do it using small spoonfuls to stir it with the flour and salt until you get the ideal texture.
  3. If you detect that the mixture is getting especially sticky, choose to add more flour. Thus, the material will have a greater consistency.
  4. Add the food coloring to add color to the clay if you want.
  5. Finally, knead the mixture and you can start creating figures with this homemade material.
