A project log for Mood Gradient
A slider that you can move to express your current emotion.
corbincorbin 05/01/2023 at 18:260 Comments
Last week, we put in the code for the two feather boards to talk to each other. Now, we are going to put in code so that the feather boards can control the slide potentiometer to remotely control the slider, which has been 3D printed. We are also working on designing the gradients, and working on physically connecting the slider to the rail/gear design we have to move it. Last week we finished laser cutting the final wooden boxes, and now we have to assemble them, and put everything inside.
5/3/23
We have made inputted the code to get the value from the slide potentiometer, and it is working. For the client side of the two feather boards, all we have to do is put it into the server and client code, and make it send a signal to the other feather board when the value changes. The wooden box was difficult to assemble, but after sanding the parts that interlock together, it and the small box have been assembled.
