Control From the Upper Deck
A project log for Home Robot--What Can It Do?
Using existing robots for guidance, I plan to design and construct a household droid.
mike-rigsbyMike Rigsby 04/19/2023 at 21:090 Comments
Now the movement instructions come from the upper deck--an Arduino Mega.
It was necessary to rewrite the software for the motor controller (stepper control test.ino) and add control lines as well as set up the Arduino Mega on the upper deck.
Movement control information can now be written to the upper deck Arduino--which will send control signals to the lower deck.
The current program (homely master.ino) merely goes forward, turns around, returns and turns around.
