This simple and cheap project turns your standard garage door opener into a smart garage door opener.
Open/Close the door remotely using a mobile device or home assistant
Check open/close status from a mobile device
The hardware will cost around $10 and is very simple to wire-up and configure. The hardware includes an ESP32 or NodeMCU board, a single relay module, magnetic door switch.
