Mercator Origins - Audio Guidance Enabled - Final Assembly
A project log for "Mercator Origins": Sat Nav & Telemetry for Divers
Want to map your dive? Want to navigate like a pro? Even if you are vision-impaired, this will empower you to navigate our underwater world.
mark-b-jonesMark B Jones 05/30/2023 at 11:580 Comments
The completed assembly - navigation console and audio module, with surface float.
And from another vantage point
Side view of the spool in close up
The navigation console (powered through the cable from the float)
The audio guidance module (independent power supply)
