Microfluid pad
A project log for Enhancer mask lite
The mask of the future that turns anyone who wears it into a cyborg.
m-bindhammerM. Bindhammer 05/14/2023 at 08:290 Comments
The microfluid pad is used to distribute neurotransmitters, stimulants, medicine, etc. dissolved in a carrier substance (penetration enhancer) on the skin. While in the first prototype, I cast an ABS filament structure in silicone and then dissolved it with acetone to make a microfluid pad, I now want to try another option. For this, three 1mm thick clear acrylic glass sheets are cut out with the laser and glued together in sandwich construction. To do this, I have drawn the three sheets in Inkscape.
