Possible Upgrade
A project log for Beeper Box: Analog V2F
A very useful test fixture to convert the voltage or impedance seen on its input to a variable frequency audible tone
john-guyJohn Guy 04/21/2023 at 17:540 Comments
I saw another idea here for a continuity tester which has much lower thresholds. As designed  it is hard to tell the difference between 0Ω and about 20Ω or so, rather this is optimized to measure 100Ω to 2kΩ or so.
So, perhaps, a range switch to go 100x on the bias current, 40µA to 4mA.
I will be thinking on this ........
