the buttons make sound
A project log for communication board
the communication board for school
molendaccMolendacc 05/10/2023 at 17:200 Comments
We finally got the buttons to make sound when we press them. We had to use the hex codes for the buttons and the files on the micro SD that was in the serial mp3 player. w coded it so that when you push the button it would read the hex code of the button and then play the respective file we wanted to play if that button was pushed.
