More details about the hardware
A project log for Repurposed wifi controller as GPS-based NTP server
An old Meru MC1500 wifi controller retrofitted with Debian and a GPS receiver becomes an accurate private NTP server
remi-serriereRemi Serriere 04/21/2023 at 20:030 Comments
First, it looks like this connector there is a parallel port. It is connected to a PACSZ1284 chip so there might be something to do with this later!
And a few information about the hardware from the OS:
lspci
root@rsfo-ntp01:~# lspci
00:00.0 Host bridge: Intel Corporation Mobile 915GM/PM/GMS/910GML Express Processor to DRAM Controller (rev 04)
00:02.0 VGA compatible controller: Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller (rev 04)
00:02.1 Display controller: Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) PCI Express Port 1 (rev 04)
00:1c.1 PCI bridge: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) PCI Express Port 2 (rev 04)
00:1d.0 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #1 (rev 04)
00:1d.1 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #2 (rev 04)
00:1d.7 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB2 EHCI Controller (rev 04)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev d4)
00:1f.0 ISA bridge: Intel Corporation 82801FBM (ICH6M) LPC Interface Bridge (rev 04)
00:1f.2 IDE interface: Intel Corporation 82801FBM (ICH6M) SATA Controller (rev 04)
00:1f.3 SMBus: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) SMBus Controller (rev 04)
02:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
03:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
lscpu
root@rsfo-ntp01:~# lscpu
Architecture:                    i686
CPU op-mode(s):                  32-bit
Byte Order:                      Little Endian
Address sizes:                   32 bits physical, 32 bits virtual
CPU(s):                          1
On-line CPU(s) list:             0
Thread(s) per core:              1
Core(s) per socket:              1
Socket(s):                       1
Vendor ID:                       GenuineIntel
CPU family:                      6
Model:                           13
Model name:                      Intel(R) Celeron(R) M processor         1.50GHz
Stepping:                        8
CPU MHz:                         1500.033
BogoMIPS:                        3000.06
Vulnerability Itlb multihit:     KVM: Mitigation: VMX unsupported
Vulnerability L1tf:              Mitigation; PTE Inversion
Vulnerability Mds:               Vulnerable: Clear CPU buffers attempted, no mic
                                 rocode; SMT disabled
Vulnerability Meltdown:          Mitigation; PTI
Vulnerability Mmio stale data:   Unknown: No mitigations
Vulnerability Retbleed:          Not affected
Vulnerability Spec store bypass: Vulnerable
Vulnerability Spectre v1:        Mitigation; usercopy/swapgs barriers and __user
                                  pointer sanitization
Vulnerability Spectre v2:        Mitigation; Retpolines, STIBP disabled, RSB fil
                                 ling, PBRSB-eIBRS Not affected
Vulnerability Srbds:             Not affected
Vulnerability Tsx async abort:   Not affected
Flags:                           fpu vme de pse tsc msr pae mce cx8 apic sep mtr
                                 r pge mca cmov clflush dts acpi mmx fxsr sse ss
                                 e2 ss tm pbe nx bts cpuid pti
lsusb
root@rsfo-ntp01:~# lsusb
Bus 001 Device 002: ID 18d1:4ee7 Google Inc. Nexus/Pixel Device (charging + debug)
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
sensors-detect (after installing lm-sensors and i2c-tools). Unfortunately, the "sensors" command doesn't show any sensor, yet...
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `w83627hf':
  * ISA bus, address 0xa00
    Chip `Winbond W83627THF/THG Super IO Sensors' (confidence: 9)
i2cdetect
root@rsfo-ntp01:~# echo i2c-dev >> /etc/modules
root@rsfo-ntp01:~# systemctl restart kmod
root@rsfo-ntp01:~# i2cdetect -l
i2c-3   i2c             i915 gmbus panel                        I2C adapter
i2c-1   i2c             i915 gmbus ssc                          I2C adapter
i2c-6   i2c             i915 gmbus dpd                          I2C adapter
i2c-4   i2c             i915 gmbus dpc                          I2C adapter
i2c-2   i2c             i915 gmbus vga                          I2C adapter
i2c-0   smbus           SMBus I801 adapter at 0400              SMBus adapter
i2c-5   i2c             i915 gmbus dpb                          I2C adapter
root@rsfo-ntp01:~# i2cdetect -y 0
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:                         08 -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- 44 -- -- -- -- 49 -- -- -- -- -- --
50: 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- 61 -- -- -- -- -- -- -- 69 -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
root@rsfo-ntp01:~# i2cdetect -y 1
00:                         -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
root@rsfo-ntp01:~# i2cdetect -y 2
root@rsfo-ntp01:~# i2cdetect -y 3
root@rsfo-ntp01:~# i2cdetect -y 4
root@rsfo-ntp01:~# i2cdetect -y 5
00:                         08 09 0a 0b 0c 0d 0e 0f
10: 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f
20: 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f
30: 30 31 32 33 34 35 36 37 38 39 3a 3b 3c 3d 3e 3f
40: 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d 4e 4f
50: 50 51 52 53 54 55 56 57 58 59 5a 5b 5c 5d 5e 5f
60: 60 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f
70: 70 71 72 73 74 75 76 77
root@rsfo-ntp01:~# i2cdetect -y 6
Let's execute "sensors" again:
root@rsfo-ntp01:~# sensors
w83627thf-isa-0a00
Adapter: ISA adapter
in0:           1.29 V  (min =  +0.70 V, max =  +1.87 V)
in1:           3.31 V  (min =  +0.72 V, max =  +0.05 V)  ALARM
in2:           3.22 V  (min =  +2.61 V, max =  +3.82 V)
+5V:           4.96 V  (min =  +1.52 V, max =  +2.19 V)  ALARM
in4:           3.58 V  (min =  +2.67 V, max =  +2.30 V)  ALARM
5VSB:          4.91 V  (min =  +0.05 V, max =  +6.69 V)
Vbat:          3.23 V  (min =  +0.96 V, max =  +2.43 V)  ALARM
fan1:        7031 RPM  (min =  907 RPM, div = 8)
fan2:        7031 RPM  (min = 2596 RPM, div = 8)
fan3:        7336 RPM  (min = 1622 RPM, div = 8)
temp1:        +32.0°C  (high = +98.0°C, hyst = +12.0°C)  sensor = thermistor
temp2:        +28.5°C  (high = +80.0°C, hyst = +75.0°C)  sensor = CPU diode
temp3:        +39.0°C  (high = +80.0°C, hyst = +75.0°C)  sensor = thermistor
beep_enable: enabled
