Broad Overview of a buck regulator
A project log for OpAmp Buck Regulator
A quad OpAmp Makes a Buck Regulator
aaron-lagerAaron Lager 04/19/2023 at 03:580 Comments
First I started with the major building blocks of a buck regulator:
  1. Oscillator
  2. PWM
  3. Feedback
Poking around on the googles for opamp PWM, I ran across this great video series: Op-Amps, PWM
I quickly fired up LTSpice and simulated the circuits.  It did work, but the waveforms were a little too off for my tastes.  And, more importantly, it required a dual supply to operate.
Basic operation is as follows:
The  first opamp is a oscillator circuit used to make a square wave.  The square wave is then integrated by the second opamp circuit, which produces a triangle wave.
The search continues...
