Enclosure redesigns
A project log for Dummy battery for a gopro 7
x
lion-mclionheadlion mclionhead 03/31/2024 at 01:530 Comments
While the battery door is not removable according to the internet.
It can be removed by cutting off a small bit of plastic.
It's a very complicated mechanism if it wasn't designed in China.  Suspect it was designed in China.
The door can be reinserted as a gap filler, if the camera is stored in an enclosure.  It still won't shut down properly.
The easiest wire routing for the enclosures ended up being a notch.  The trick is keeping the buck converter always powered in order to retain the system clock.
All new tripod mount with cooling fan.
It took 3 tries to get the battery flush with .32 layers.
