PS3/4 Controller
A project log for $10 Robot!
A super cheap educational robotics platform. Everything you need to build and program a simple robot.
neil-lambethNeil Lambeth 10/03/2023 at 10:360 Comments
We already use Playstation controllers for the other robots that we use in our club, there's also a prety good chance that the students will have them at home. So It makes sense to use them with the $10Robot! as well.
A quick bit of googling lead me to an Arduino library: PS4-esp32 (there's also a library available for PS3 controllers).
The first thing you have to do it get the MAC address of your controller. You can do this by using the Sixaxis Pair Tool, I used this one.  Just install it then plug in your controller with a USB cable and it will show you the MAC address. Make a note of it as you'll need it in your Arduino program.
After installing the Arduino library, it was pretty easy to get up and running, as there are a number of example programs included. I used PS4ReceiveData as my starting point. It doesn't control a robot yet, it just shows the button presses in the serial monitor.  I modified the original code a little, just so that it makes the serial output a bit easier to read.
#include <PS4Controller.h>
//Set up variables
int LX = 0;
int LY = 0;
int R_X = 0;
int RY = 0;
int LX_old = 0;
int LY_old = 0;
int RX_old = 0;
int RY_old = 0;
int deadBand = 8;
bool connected = 0;
void setup() {
  Serial.begin(115200);
  PS4.begin("0a:0b:0c:0d:oe:0f"); // Enter your MAC address here.
  Serial.println("Ready.");
  delay(200);
void loop() {
  if ((PS4.isConnected()) && (connected != 1)) {
    Serial.println("Connected!");
    Serial.printf("Battery Level : %d\n", PS4.Battery());
    connected = 1;
  // Below has all accessible outputs from the controller
  if (PS4.isConnected()) {
    if (PS4.Right()) Serial.println("Right Button");
    if (PS4.Down()) Serial.println("Down Button");
    if (PS4.Up()) Serial.println("Up Button");
    if (PS4.Left()) Serial.println("Left Button");
    if (PS4.Square()) Serial.println("Square Button");
    if (PS4.Cross()) Serial.println("Cross Button");
    if (PS4.Circle()) Serial.println("Circle Button");
    if (PS4.Triangle()) Serial.println("Triangle Button");
    if (PS4.UpRight()) Serial.println("Up Right");
    if (PS4.DownRight()) Serial.println("Down Right");
    if (PS4.UpLeft()) Serial.println("Up Left");
    if (PS4.DownLeft()) Serial.println("Down Left");
    if (PS4.L1()) Serial.println("L1 Button");
    if (PS4.R1()) Serial.println("R1 Button");
    if (PS4.Share()) Serial.println("Share Button");
    if (PS4.Options()) Serial.println("Options Button");
    if (PS4.L3()) Serial.println("L3 Button");
    if (PS4.R3()) Serial.println("R3 Button");
    if (PS4.PSButton()) Serial.println("PS Button");
    if (PS4.Touchpad()) Serial.println("Touch Pad Button");
    if (PS4.L2()) {
      Serial.printf("L2 button at %d\n", PS4.L2Value());
    if (PS4.R2()) {
      Serial.printf("R2 button at %d\n", PS4.R2Value());
    if (PS4.LStickX()) {
      LX = PS4.LStickX();
      //Serial.printf("Left Stick x at %d\n", PS4.LStickX());
      // Use the deadband to make sure the value goes back to zero when you let go of the stick.
      if ((LX < deadBand) && (LX > -deadBand)) {
        LX = 0;
    if (PS4.LStickY()) {
      LY = PS4.LStickY();
      if ((LY < deadBand) && (LY > -deadBand)) {
        LY = 0;
    if (PS4.RStickX()) {
      R_X = PS4.RStickX();
      if ((R_X < deadBand) && (R_X > -deadBand)) {
        R_X = 0;
    if (PS4.RStickY()) {
    RY = PS4.RStickY();
      if ((RY < deadBand) && (RY > -deadBand)) {
        RY = 0;
    // Only print the values if they have changed
    if ((LX != LX_old) || (LY != LY_old) || (R_X != RX_old) || (RY != RY_old)) {
      Serial.printf("LX = %04d, LY = %04d, RX = %04d, RY = %04d\n", LX, LY, R_X, RY);
    LX_old = LX;
    LY_old = LY;
    RX_old = R_X;
    RY_old = RY;
    if (PS4.Charging()) Serial.println("The controller is charging");
    if (PS4.Audio()) Serial.println("The controller has headphones attached");
    if (PS4.Mic()) Serial.println("The controller has a mic attached");
Here's the serial output:
Here's the full modified code to control the $10Robot!:
//Set up variables
int LX = 0;
int LY = 0;
int R_X = 0;
int RY = 0;
int LX_old = 0;
int LY_old = 0;
int RX_old = 0;
int RY_old = 0;
int deadBand = 8;
bool connected = 0;
bool up = 0;
bool down = 0;
bool left = 0;
bool right = 0;
void setup() {
  PS4.begin("b8:27:eb:23:65:fd");
  //ESP32 pin setup
  pinMode(2, OUTPUT); // LED
  pinMode(18, OUTPUT); // Motor 1a
  pinMode(19, OUTPUT); // Motor 1b
  pinMode(25, OUTPUT); // Motor 2a
  pinMode(26, OUTPUT); // Motor 2b
void loop() {
    connected = 1;
    if (PS4.Right()) {
      if (right == 0) {
        Serial.println("Right Pressed");
        Serial.println("Turn Right");
      right = 1;
      digitalWrite(18, 0);
      digitalWrite(19, 1);
      digitalWrite(25, 1);
      digitalWrite(26, 0);
    else if (right == 1) {
      right = 0;
      Serial.println("Right Released");
      Serial.println("STOP");
      digitalWrite(19, 0);
      digitalWrite(25, 0);
    if (PS4.Down()) {
      if (up == 0) {
        Serial.println("Down Pressed");
        Serial.println("Backwards");
      down = 1;
      digitalWrite(18, 1);
    else if (down == 1) {
      down = 0;
      Serial.println("Down Released");
    if (PS4.Up()) {
      if (up == 0) {
        Serial.println("Up Pressed");
        Serial.println("Forwards");
      up = 1;
      digitalWrite(26, 1);
    else if (up == 1) {
      up = 0;
      Serial.println("Up Released");
    if (PS4.Left()) {
      if (left == 0) {
        Serial.println("Left Pressed");
        Serial.println("Turn Left");
      left = 1;
    else if (left == 1) {
      left = 0;
      Serial.println("Left Released");
    if (PS4.L2()) {
    if (PS4.R2()) {
      LX = PS4.LStickX();
        LX = 0;
      LY = PS4.LStickY();
        LY = 0;
        R_X = 0;
    RY = PS4.RStickY();
        RY = 0;
    LX_old = LX;
    LY_old = LY;
    RX_old = R_X;
    RY_old = RY;
 This just uses the DPAD buttons to control the robot as it's an easy starting point. I'll add code to use the joysticks with speed control at a later date.
