The end is near
06/15/2023 at 13:37 • 0 commentsWow. That sounds morbid, doesn't it? How about "The project is nearly finished'?
I worked out the remaining software glitches, so now the device's operation is nearly flawless!
I am not necessarily tooting my own horn since I really use it (the chair, not the horn).
The long-awaited video will be coming as soon as I convince my wife to show-off her modeling abilities. Trust me, you do not want ME to demonstrate it!!
A note about PICO's pull-up resistors
06/02/2023 at 21:13 • 0 commentsThe Pin.PULL_UP settings are now Pin.PULL_DOWN, and not really needed.
Why?
Because by default, the controller (button) contacts are normally-closed to ground, thus eliminating the need of a PULL_DOWN resistor. The normally-open side is +5VDC.
Yeah but...
There is always a caveat: The above reigns true IF a controller is plugged in. If not, the inputs will "float" in an incalculable state. That would be bad, am I right? (The answer is yes)
The bottom line:
PICO's internal Pin.PULL_DOWN setting will work just fine for unconnected controllers.
Escaping the nasties, bugs, issues, etc. is impossible
06/01/2023 at 13:52 • 0 commentsI came across some hindrances when moving from the "Proof of Concept" to "Prototype" stage.
Or better said, from the “plastic case” to an “aluminum case” stage.
Aluminum is a conductor, plastic is not.
Consequently, well, you get it.
Enough said.
Oh, and by the way, the 5-pin DIN connector, when used for a factory powered chair/recliner/bed (and unlike its shared MIDI use), the case is very-much used. If you read any of my previous logs, in hindsight this is precisely why I fried my original Raspberry PI.
Why didn't I learn?
Ahead of schedule
05/31/2023 at 01:55 • 0 commentsI'm almost a month early getting version 2 (the prototype) built. Videos of it in operation will be added within the week.
Prototype: Components mounted
05/23/2023 at 23:01 • 0 commentsMaking progress..,.
Next: Driling holes in the end-panels (16 of 'em)
Hello prototype stage
05/15/2023 at 22:57 • 0 commentsAt this point, I’m moving the project out of my ‘proof of concept’ stage and into the prototype stage. This new stage boasts a modern design with its appearance looking much more professional.
For the hardware, the current grey plastic case that looks so horrible is being replaced with a smaller, black anodized aluminum case with chromed LED holders, and an external USB connector.
Software improvements include allowing better control, self-learning timing, and much more.
The new prototype version is currently being developed, and I’ll be posting pictures as milestones are reached. Remember, I’m the sole person doing every aspect of hardware development, software updates, testing, and documentation. So please be patient with me! My goal is to have the prototype completed by 6/30/2023.
05/01/2023 - Pull-my-hair-out UP/DOWN resistors
05/01/2023 at 21:55 • 0 commentsIt turns out the PICO's internal pull-up resistors are somewhat undependable as midnightelf expains at https://forums.raspberrypi.com/viewtopic.php?f=144&t=315020
I'm adding external resistors, plus a secret surprise!!
03/11/2023 - Well now, life after PI
04/29/2023 at 20:54 • 0 commentsThe Raspberry PICO HW works out fine. By adding a 2-channel relay board, which is optically connect and directly controlled, the unit makes sense. Although the switch from Python to microPython had a learning curve, it was small.
Oh, the HW...
H = pre-soldered header pins
W = WiFi included
...and only $15? Heck yeah
02/15/2023 - I wallowed in self-pity
04/29/2023 at 20:39 • 0 commentsAfter kicking myself for blowing up the PI and wallowing in self-pity, a did a little research, eventually running across the Raspberry PICO. Cheap, small... it's perfect!
How to cook a Raspberry PI
04/29/2023 at 20:33 • 0 commentsIt turns out, if you shove 24vcd down one of Raspberry PI 's GPIO pins, it pretty much trashes it, making it unrecoverable. In short, throw it away.
