111nF disc capacitor
Solder 1nF disc capacitors at C1 and C3
121K resistor
Solder 1K resistor at R10
13BioAmp cable connector
Solder 3 pin JST PH 2.00mm to connect the BioAmp Cable with your Muscle BioAmp BisCute.
14I/O header pins
15Quad OpAmp
Solder Quad OpAmp which is the heart of your Muscle BioAmp BisCute. As we are testing new ICs with each version update you may find different Quad OpAmps in the kit depending on the time you bought the kit from us.
16BisCute baked, best served hot ;)
You are ready to use your own Muscle BioAmp BisCute EMG sensor to create cool HCI projects.
