Classic 47, a DIY kit for single Op Amp´s
A project log for Listen to the Op Amp´s
Can you hear the difference between Op Amp´s? Yes! With this headphone amplifier.
stephan-martinStephan Martin 05/22/2023 at 18:540 Comments
Search online for "Classic 47 Headphone" and you will find kit´s to solder that are basically cmoy headphone amplifiers.
As im still waiting for the PCB´s i soldered up such a kit to give it a go:
Both Op Amp´s are already in sockets and its delivered with a set of NE5532.
So far i have given it a quick test to confirm it works, and then tried to hear a difference against OPA604 and AD8065. But i cannot say that its a clear difference...
