Wired Up
A project log for LED Stairway
The stairway has been upgraded with some LEDs on every step and are triggered to run up or down when you want to use the stairs.
pmtPMT 07/23/2014 at 15:520 Comments
Since a few days I've wired the circuit board. Soldered in the MCU with its own breakout PCB. Have had a little trouble with the UTP cable that i use for connecting the sensors. They are solid and tend to break quite easily.
Now its time for installing it, and give it a test run.
