meteoboard
a colorful weather forecast display
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
meteoboard is a LED matrix displaying weather forecast with color mapping to weather condition or temperature values. for example sunny weather is obviously yellow and rain condition is represented with 3 shades of blue. see the user guide for detailed color/value mapping.
with a bit of practice it allows an instant knowledge of weather forecast, on a decorative object. the LED matrix can also be used to display various animations.
inspired by maketvee's Wooden LED Gaming Display
https://www.instructables.com/Wooden-LED-Gaming-Display-Powered-by-Raspberry-Pi-/
some touch buttons allow control of the display, switching from one city to another or changing animation.
a PIR sensor and ambient light sensor are included, to switch on LEDs only when necessary, at the right brightness.
the LED matrix is designed on OpenSCAD to be laser cut, with a parametric method which allows to be tweaked for other applications.
